Api session event editor netfunction remove all attributes
API Endpoint: api/session/event/editornetfunction/remove_all_attributes/
Description: Remove all Attributes of a Net Function
0 REQUIRED (NET_FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) Net Functions
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetfunction/remove_all_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetfunction/remove_all_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetfunction/remove_all_attributes/", options)
