Api session event editor geolink
Revision as of 10:26, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeolink/
API Endpoints for Geo Link editing.
Name Description
add Add a new CustomGeoLink with a name and a Geo Link Type
duplicate Duplicate existing Geo Link
remove Remove existing Geo Link
set_name Set the name of a CustomGeoLink
Additional API Endpoints:
Name Description
remove_additional Remove additional Attribute injection from the created feature
remove_function Remove the Function of a CustomGeoLink
remove_mapping Remove mapping of original Attribute name to a new name in the created feature
remove_matching Remove matching of incoming features against Attributes
set_additional Inject additional Attributes into the created feature
set_function Set the Function of a CustomGeoLink
set_geometry_mode Set the Geometry Mode used by a CustomGeoLink to interpret Feature Geometries
set_line_buffer Set the distance used by a CustomGeoLink to buffer Line Geometries
set_mapping Map original Attribute name to a new name in the created feature
set_matching Match incoming features against this Attribute name and value
set_point_buffer Set the distance used by a CustomGeoLink to buffer Point Geometries
set_priority Set the priority of a CustomGeoLink
