Api session event editor geolink set point buffer
API Endpoint: api/session/event/editorgeolink/set_point_buffer/
Description: Set the distance used by a CustomGeoLink to buffer Point Geometries
0 REQUIRED (GEO_LINK Integer ID or multiple integer values in array [1, 2, 3]) Geo Links (custom)
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Buffer Distance
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_point_buffer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_point_buffer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/set_point_buffer/", options)
