Api session event editor geolink remove additional
API Endpoint: api/session/event/editorgeolink/remove_additional/
Description: Remove additional Attribute injection from the created feature
0 REQUIRED (GEO_LINK Integer ID or multiple integer values in array [1, 2, 3]) Geo Links (custom)
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Attribute Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/remove_additional/", options)
