Api session event editor geolink set mapping
API Endpoint: api/session/event/editorgeolink/set_mapping/
Description: Map original Attribute name to a new name in the created feature
0 REQUIRED (GEO_LINK Integer ID or multiple integer values in array [1, 2, 3]) Geo Links (custom)
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Original Attribute Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) New Attribute Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Original Attribute Name 1", "New Attribute Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Original Attribute Name 1", "Original Attribute Name 2", "Original Attribute Name 3" ], [ "New Attribute Name 1", "New Attribute Name 2", "New Attribute Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Original Attribute Name 1", "New Attribute Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/", options)
