Api session event editor
Revision as of 10:25, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/
API Endpoints for Generic Editor Endpoints for creating and updating a Project
Name Description
activate_testrun Start or stop a Scenario Testrun
clear_map Remove all geospatial data of the Project, such as Buildings, Areas, etc
set_initial_map_size Set the size of the map. This can only be done once
set_scheduled_update Schedule a long-running update of all active Overlays, Indicators, Panels and Triggers
start_map_creation Set the Project's georeference center Point to the provided coordinates and begin automatically loading available data
update Calculate all active Overlays, Indicators, Panels and Triggers and wait for the update. Note: for long-running calculations use: set_scheduled_update/ to schedule an update
update_with_id Waits for update of all active Overlays, Indicators, Panels and Triggers with unique ID. Note: for long-running updates use: set_scheduled_update/ to schedule an update
