Api session event editor set initial map size
API Endpoint: api/session/event/editor/set_initial_map_size/
Description: Set the size of the map. This can only be done once
| 0 | REQUIRED | (Integer number) | Width of the map | |
| 1 | REQUIRED | (Integer number) | Height of the map |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editor/set_initial_map_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editor/set_initial_map_size/", options)
