Api session event editor overlay set rasterization
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_rasterization/
Description: Set the type of rasterization used by a Average, Combo or Distance Overlay
0 REQUIRED (OVERLAY Integer ID) Overlay (Average, Combo or Distance)
1 REQUIRED (Enumeration) Rasterization type FIRST, MAX, MIN, SINGLE_LAYER or GRID
2 OPTIONAL (Enumeration) Maplink (will only affect the SINGLE_Layer rasterization type): Buildings, Terrains, Areas, Neighborhoods
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "FIRST" ]'
JavaScript example POST
 body: '[ 1, "FIRST" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/", options)
