Api session event editor indicator excel min log time
Revision as of 14:51, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/excel_min_log_time/
Description: Set the minimum time for a performance entry to be recorded in an Excel Sheet Call Tree
0 REQUIRED (Integer number) Time in milliseconds
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '32'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '3'
JavaScript example POST
 body: '32'
fetch("https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/", options)
