Api session event editor specialeffect add particle pair
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorspecialeffect/add_particle_pair/
Description: Add a new Particle Emitter to a Special Effect
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/add_particle_pair/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/add_particle_pair/", options)
