Api session event editor netload generate paths
API Endpoint: api/session/event/editornetload/generate_paths/
Description: Connect Net Loads to an existing Net by adding Net Lines with the provided Net Function. Net Lines are generated with a Search Range for paths to existing Net Nodes and a Merge Range to combine Net Nodes.
| 0 | REQUIRED | (NET_FUNCTION Integer ID) | Net Function | |
| 1 | REQUIRED | (NET_LOAD Integer ID or multiple integer values in array [1, 2, 3]) | Net Loads | |
| 2 | REQUIRED | (Floating point number) | Search Range | |
| 3 | REQUIRED | (Floating point number) | Merge Range |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 63, 66 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], 60, 12 ]'JavaScript example POST
body: '[ 1, 1, 63, 66 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_paths/", options)
