Excel Sheet
Excel Sheet is an Item that stores data of an Excel File.
Properties
An Excel Sheet item has the following properties:
- Byte array of the Excel File contents
- Name of the file; Limited to lowercase with underscores.
- Uploader name and date
- Warnings from Simulation Core
- Optional certification:
- Certificate Author
- Certificate Path
- Certificate State: NONE, CERTIFIED, UNCERTIFIED
Simulation Core Instances
A single Excel Sheet can be referenced by multiple Panels and Indicators. Indicator and Panel calculators can fill their instance of an Excel Sheet with their specific TQL Queries. A specific TQL query example is: SELECT_NAME_WHERE_INDICATOR_IS_ID
- Contrary to its name, an Excel Sheet item can hold the contents of an Excel file with multiple sheets.
- An Excel Sheet cannot be removed while it is referenced by a Panel or Indicator.
API Endpoints
