How to create a new Project
The Tygron Platform provides the ability to generate a project based on real data. After selecting the area on the map, the wizard will populate the project with buildings and terrain type, based on data from various Sources, such as OpenStreetMap if applicable. Roads and structures are placed accordingly. Terrain, including rivers and banks, is shaped using a Digital Terrain Model, creating a realistic 3D Visualization of the real-world area.
How to generate a project based on real data:
- Log in to the online Tygron Platform
- Select New Project
- Name the project as desired
- Opt to create a new project, or to base it on a template.
- When creating a new project, set the localization options.
- When using a template, select the template which the new Project should be based on.
- Select the desired language, and continue.
- Select the size of the project map with the slider
- Navigate to or search for your location with the search bar if needed
- Position the selection square over your chosen area using the left mouse button; use the right mouse button to pan the map.
- Choose to use the selection on the map and all it's connected geographical data or create an empty project
- Start creating the project by selecting the Generate map button
- Let the Wizard generate the area
- After the rendering process is complete, continue editing the newly created project.
