Wind turbine (Indicator)
Revision as of 10:49, 13 October 2026 by Frank@tygron.nl (talk | contribs)
The Wind turbine indicator calculates the number of wind turbines in the project area and the amount of generated power in MW. The amount is calculated by comparing the current situation and the planned situation. By setting a target value it is possible to experiment with scenarios for renewable energy in the project area. For example, the target for the generated power in the project area is 10 MW. This target then needs to be reached by planning both large and normal wind turbines in the project area. The target value and the amount of power per type of wind turbine is adjustable, which makes this indicator scalable for different types of projects.
This indicator is useful for projects where:
(one of the) goals is to work on reaching a certain renewable energy target different spatial plans are compared using the 3D Visualization the project area should become climate adaptive
Indicator panel
The wind turbine indicator.
The indicator panel shows the following information:
  • The number of current turbines
  • The number of current large turbines
  • The number of planned turbines
  • The number of planned large turbines
  • The total amount of generated power in MW
  • The score per area
Calculation
The indicator uses the turbine count to determine total power generation (MW). The normal size turbine generates 1 MW and the large turbine generates 3 MW. The amount of MW generated per turbine is based on values found at https://www.windcentrale.nl/blog/hoeveel-energie-levert-een-windmolen-op/.
The following formula is used:
(number of turbines normal * 1MW) + (number of turbines large * 3MW)= total amount of MW
Score
The score is represented in a progress bar, with a scale from 0 to 100%.
Additional configurations
For this indicator, the Global POWER_TARGET needs to be added. Also the Attribute POWER needs to be added to the functions "Windmill" and "Windmill (Large)" in the function values table See below for the steps:
Add the global
The target is set in a Global. To learn more about what a global is, please go to the Globals page.
Wind turbine (Indicator):
  1. Select the Current situation and then hover over the TQL Queries button in the ribbon header.
  2. Click on the Add Global button in the hover panel. A new global named VARIABLE will be added to the left panel.
  3. Select the global VARIABLE.
  4. In the right panel, change the name to POWER_TARGET.
  5. Change the start value to a number representing your total target.
  6. Hover over the Auto update icon and choose for Reset to Start values (faster) to update your project.
Add the attribute
The generated power per type of wind turbine is set in the function values table. To learn more about this table, please go to the function values table page.
  1. Select the Current tab and hover over the Buildings button in the ribbon header
  2. Click on Edit function values in the hover menu.
  3. Set the Category filter on Other.
  4. Click in the left bottom corner on the Add button after Function.
  5. In the new panel, choose the Windmill function and click on Apply.
  6. Repeat the steps 3 and 4 for the Windmill large function
  7. In the bottom-left corner, enter "POWER" under Attributes and click Add.
  8. Search for the attribute POWER in the table and set the desired values for each type of windmill by clicking two times on the value and entering a new value.
  9. Hover over the Auto update icon and choose for Reset to Start values (faster) to update your project.
