Water Module benchmarks
Revision as of 08:15, 13 October 2026 by Frank@tygron.nl (talk | contribs)
In order to validate the implementation of the water module in the Tygron Platform, several shallow water related benchmarks have been performed. The following benchmarks are available for review:
Rainfall Benchmarks
Flooding Benchmarks
Groundwater Benchmarks
Perform your own Benchmarks
  • Some of the Benchmarks mentioned above are available in your own domain. Please contact Tygron Support for more information.
  • Confirm your own basic water calculations by composing a test bed in the Tygron Platform using the Testbed tutorial.
  • Basic test set-ups are available via the Water Module Testbed, located in the main menu under Edit projects.
Tygron has automated most of these benchmarks for its Tygron Platform's build process. This way, each implementation change made to the server and the Water Module is tested in terms of code, data and hardware.
Additional test cases
