Excel Sheet
Revision as of 13:18, 30 September 2026 by Frank@tygron.nl (talk | contribs)
Excel Sheet is an Item that stores data of an Excel File.
Properties
An Excel Sheet items has the following properties:
  • Byte array of the Excel File contents
  • Name of the file; Limited to lowercase with underscores.
  • Uploader name and date
  • Warnings from Simulation Core
  • Optional certification:
    • Certificate Author
    • Certificate Path
    • Certificate State: NONE, CERTIFIED, UNCERTIFIED
Simulation Core Instances
A single Excel Sheet can be referenced by multiple Panels and Indicators. Indicator and Panel calculators can fill their instance of an Excel Sheet with their specific TQL Queries. An example is of a specific TQL Query is: SELECT_NAME_WHERE_INDICATOR_IS_ID
  • Contrary to its name, an Excel Sheet item can hold the contents of an Excel file with multiple sheets.
  • An Excel Sheet cannot be removed while it is referenced by a Panel or Indicator.
API Endpoints
