How to edit the Camera Position
When the "Edit Camera Position" button is selected, you enter camera editing mode. This mode allows you to edit the camera location and orientation for the selected Key Point. The "Edit Camera Position" button is replaced by options in the right panel to store the camera position. In the 3D Visualization, an object will be visible to help orient the camera.
Moving the Camera
While editing the camera position for a cinematic, you have more exact control over the camera. These controls differ from normal movement and can be operated via mouse, keyboard, or both.
Store Camera Position
When the camera is in the position you want for this Key Point, you can press "Store Camera Position" to store the current location and orientation of the camera for this Key Point.
Stop Editing Camera Position
When you are done editing the camera position for this Key Point, you can press "Stop Editing Camera Position" to leave the camera editing mode. The camera will reset to the camera position set for this Key Point. If you store your current camera position right before stopping camera editing mode, you will not see the camera move.
