How to add and remove an Attribute
Attributes can be added to features such as Buildings, Stakeholders, Indicators, Areas and Overlays.
Attribute management is generally consistent, though some features require additional assets (e.g., indicators or terrains). Refer to the feature's main article for details.
Adding an Attribute
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an Attribute:
- Select in the editor the feature where you would like to add an Attribute to
- Select the Attribute tab on the right side
- Enter a name/ value pair for the new Attribute
- Select 'Save New Attribute'
- Notice the new attribute is added to the feature
1. Select the feature where you would like to add an Attribute to
2. Select the Attribute tab
3. Enter a name/ value pair for the new Attribute
4. Select 'Save New Attribute'
5. Notice the new attribute is added to the feature
Removing an Attribute
How to remove an Attribute:
- Select in the editor the feature where you would like to remove the Attribute from
- Select 'remove' next to the Attribute you would like to remove
- Notice the Attribute is removed
1. Select the feature where you would like to remove the Attribute from
2. Select the Attribute tab on the right side
3. Select 'remove' next to the Attribute you would like to remove
4. Notice the Attribute is removed
Removing all Attributes
To reset all attributes at once, select 'Reset Attributes' in the bottom corner on the right side.
