How to edit an Attribute
Revision as of 12:12, 8 July 2026 by Maxim@tygron.com (talk | contribs)
The right panel allows you to add new attributes. The top half displays existing Attributes, allowing you to edit them.
Many Items in a Project, ranging from Stakeholders to Overlays to Buildings, have Attributes, representing properties that can be added, changed and removed. The Attribute Tab in the right panel provides a consistent way of managing attributes of an Item.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an attribute:
  1. Select the item you wish to edit.
  2. Switch to the "Attributes" tab.
  3. Scroll to the Attribute you want to change, if necessary.
  4. Change the listed Attribute value to the desired value.
  5. The Attribute has now been changed.
  • Adding an Attribute which already exists will change the existing Attribute value to the new value.
