How to add and remove a Zone
Revision as of 13:00, 7 July 2026 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Administrative (Ribbon bar) → Show Zoning Plan (Dropdown)
The left panel allows you to add, remove and select zones.
Open the Zoning panel in the left panel to add new zones. Select "Add Zone" for unrestricted zones or "Add Zone With Categories" to limit building categories. A new zone will appear in the list of zones.
Note that when a new zone is added, it is not yet present in the 3D Visualization. Its contour must still be drawn in the 3D Visualization for it to apply.
Existing zones can be removed by selecting them, and then selecting "Remove". When a zone is removed with child zones (displayed in the left panel as being one or more subitems of the zone), the child zones remain.
How to add a zone to the 3D Visualization:
  1. Open the Zoning panel
  2. Select "Add Zone".
How to add a zone with categories to the 3D Visualization:
  2. Select "Add Zone With Categories".
How to remove zones from the 3D Visualization:
  2. Select the zone you wish to remove.
  3. Select "Remove".
