Api session event editor zoning add
API Endpoint: api/session/event/editorzoning/add/
Description: Add a new Zone, optionally as Category Zone
| 0 | REQUIRED | (true, false) | As Category Zone | true or false |
| 200 | Integer (Zone ID) |
curl 'https://engine.tygron.com/api/session/event/editorzoning/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'JavaScript example POST
body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorzoning/add/", options)
