Green MKP (Indicator)
The green MKP Indicator calculates a grade for each different type of area based on the amount of green in this area. The allocation of the area determines the calculation of the grade. Each type of area has different parameters for the amount and value of green. For example, an area with mostly industrial buildings is allowed to have less green than a residential area.
This indicator is for example useful for projects where:
  • (one of the) goals is to work on reaching a certain green target
  • different spatial plans are compared using the 3D Visualization
  • the project area should become climate adaptive
The green MKP Indicator belongs to the set of MKP indicators. MKP stands for Environmental Quality Models (MileuKwaliteitsProfielen) and consist of up to 20 indicators to assess the built environment. The MKP and therefore the indicators are created by the Province of Utrecht. Read more about the MKP indicators and the theory behind it on this page.
Indicator panel
The Green MKP indicator.
The indicator panel shows the following information:
  • The area name
  • The score per area
Calculation
The indicator calculates the amount of m2 green per area. This is backchecked against the allocation plan per area to calculate the score per area. The following formula is used:
The calculation MKP Green indicator. The calculation of score MKP Green indicator.
Score
The score is represented in a progress bar, with a scale from 0 to 100%. Determine if you want to calculate the absolute or relative score. In general, the more green is present in an area, the higher the score is.
Additional configurations
For this indicator, the area types your project consists of have to be imported or created in the project. For the steps and how to, read the information on the general MKP page.
