How to manually edit a network
Revision as of 08:23, 6 July 2026 by Frank@tygron.nl (talk | contribs)
How to manually edit a network:
  1. How over Networks in the ribbon bar.
  2. Select the option 'Edit Network'.
  3. Select an Active Net Type. If none are available, click on the 'Activate Net Type' link.
  4. Optionally select a Net Function for newly added Net Lines.
  5. Select a draw option: 'Add', 'Remove' or 'Move'.
  6. Click in the 3D Visualization to add Net Nodes connected by Net Lines of the selected Net Function.
  7. Once ready, click on the 'Done' button.
