Api session event editor netload generate paths
Revision as of 12:22, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/generate_paths/
Description: Generate Paths
0 REQUIRED (NET_FUNCTION Integer ID) Net Functions
1 REQUIRED (NET_LOAD Integer ID or multiple integer values in array [1, 2, 3]) Net Loads
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 26, 92 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], 50, 50 ]'
JavaScript example POST
 body: '[ 1, 1, 26, 92 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_paths/", options)
