How to edit a Measure with QGIS
Revision as of 09:08, 16 June 2026 by Maxim@tygron.com (talk | contribs)
Follow the steps of the how-to's below to add a WFS layer to QGIS and edit a specific layer.
How to Add a Measure WFS to QGIS:
  1. Open a Project in Editor mode
  2. In the ribbon bar, select Future Design
  3. Click on Measures to inspect your measures
  4. In case the project does not contain a measure, add one by clicking on the Add Button.
  5. Optionally rename the added measure
  6. How over Measures in the ribbon bar and select Export Geo Data.
  7. For Filter, select the specific Measure you want to edit.
  8. Click on copy URL next to Web Feature Service (WFS)
  9. Open QGIS
  10. Hover over Layers in the ribbon bar, and under Add Layer, select Add WFS / OGC Api Feature Layer
  11. In the Data Source Manager window, Click on the New button
  12. Provide a custom name for the service
  13. Select the URL field and paste the copied WFS URL.
  14. Click on OK.
  15. Click on Connect
  16. Select the Layers you want to edit and click on Add.
  17. Close the Window.
How to Edit a Measure WFS in QGIS:
  1. With the Measure WFS Layers added by the previous How-to, select a Layer you want to edit.
  2. Additionally, add a original satellite WMS of your project to draw upon.
  3. To edit the layer, follow the steps described in How to edit your project data via WFS
