Api session event editor netload generate paths
API Endpoint: api/session/event/editornetload/generate_paths/
Description: Generate Paths
| 0 | REQUIRED | (NET_FUNCTION Integer ID) | Net Functions | |
| 1 | REQUIRED | (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) | Net Loads | |
| 2 | REQUIRED | (Floating point number) | Double | |
| 3 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 10, 83 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], 29, 50 ]'JavaScript example POST
body: '[ 1, 1, 10, 83 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_paths/", options)
