Api session event editor geolink
Revision as of 08:39, 3 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeolink/
API endpoints for Geo Link editing.
Name Description
add Add new Geo Link
duplicate Duplicate existing Geo Link
remove Remove existing Geo Link
set_name Set new name of existing Geo Link
Additional API endpoints:
Name Description
remove_additional Remove additional Attribute injection from the created feature.
remove_function Remove Function
remove_mapping Remove map orginal Attribute name to a new name in the created feature.
remove_matching Remove matching incoming features against Attribute.
set_additional Inject additional Attributes into the created feature.
set_function Set Function
set_geometry_mode Set Geometry Mode
set_line_buffer Set Line Buffer
set_mapping Map orginal Attribute name to a new name in the created feature.
set_matching Match incoming features against this Attribute name and value.
set_point_buffer Set Point Buffer
set_priority Set Priority
