Api session event editor address
Revision as of 08:39, 3 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoraddress/
API endpoints for Address editing.
Name Description
add Building Address belong to
append_attribute Appended to existing Address Attribute value
duplicate Duplicate existing Address
remove Remove existing Address
remove_attribute Remove Attribute from Address
set_attribute Set Address Attribute value
set_attributes Set multiple Address Attribute values
Additional API endpoints:
Name Description
get_building Get Building
search Search Addresses
set_addition Set Addition
set_letter Set Letter
set_number Set Number
set_point Set the Point of an Address
set_street Set Street
set_surface_size Set Surface Size
set_zip_code Set Zip Code
