Api session event editor address add
API Endpoint: api/session/event/editoraddress/add/
Description: Assign new Addresses to Buildings
0 REQUIRED (BUILDING Integer ID or multiple integer values in array [1, 2, 3]) Buildings
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Street names
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editoraddress/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Street name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoraddress/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Street name 1", "Street name 2", "Street name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Street name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/add/", options)
