Api session items addresses
API Endpoint: /api/session/items/addresses/
Edit items with events described at Api session event editor address.
Default Query:
https://engine.tygron.com/api/session/items/addresses/?token=API_TOKEN
Example Response:
  "addition" : "",
  "attributes" : {
    "BAG_ADDRESS_ID" : [ 2.02010000424801E14 ],
    "CADASTRAL_PURPOSE" : [ 1.0 ],
    "ENERGY_LABEL" : [ 4.0 ],
    "FLOOR_SPACE_M2" : [ 100.0 ],
    "INHABITANTS" : [ 1.651153 ],
    "RESIDENCE_TYPE" : [ 4.0 ]
  "id" : 0,
  "letter" : "",
  "maquetteOverride" : null,
  "name" : "1",
  "number" : 5,
  "point" : {
    "type" : "Point",
    "coordinates" : [ 659055.6574087205, 6798773.766250753, 50.08 ]
  "sourceIDs" : [ ],
  "street" : "Lijsterstraat",
  "surfaceSize" : 0.0,
  "type" : "",
  "version" : 1,
  "zipCode" : "6822LB"
  "addition" : "",
  "attributes" : {
    "BAG_ADDRESS_ID" : [ 2.02010000402527E14 ],
    "FLOOR_SPACE_M2" : [ 91.0 ],
    "INHABITANTS" : [ 3.438969 ],
  "id" : 1,
  "letter" : "",
  "name" : "2",
  "number" : 36,
  "point" : {
    "type" : "Point",
    "coordinates" : [ 658709.4792968612, 6799041.675143169, 47.528 ]
  "sourceIDs" : [ ],
  "street" : "Heselbergherweg",
  "type" : "",
  "version" : 2,
  "zipCode" : "6821JR"
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/addresses/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/addresses/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/addresses/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/addresses/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/addresses/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/addresses/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/addresses-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/addresses/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/addresses/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/addresses/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/addresses/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/addresses/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/addresses/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/addresses/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/addresses/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/addresses/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/addresses/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/addresses/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/addresses/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/addresses/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/addresses/?f=ZIPSMILE&token=API_TOKEN
Api Model Address
API Model description of Address
Name Type Description
addition String
attributes Map<String,double[]>
id int
letter String
maquetteOverride Map<String,double[]>
name String
number int
point Point Point
sourceIDs int[] Sources ID
street String
surfaceSize double
type String
version int
zipCode String
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
