Api session event editor address set point
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the Point of an Address
| 0 | REQUIRED | (ADDRESSE Integer ID or multiple integer values in array [1, 2, 3]) | Addresses | |
| 1 | REQUIRED | (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) | Points |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658677.7144431378, 6799320.273027931 ]
'Curl example multi item POST
[ [ 1, 2, 3 ], [ {
"type" : "Point",
"coordinates" : [ 658726.5164844856, 6799393.63268004 ]
"type" : "Point",
"coordinates" : [ 658754.5555700099, 6799459.991344936 ]
"type" : "Point",
"coordinates" : [ 658787.0220505259, 6799371.659957958 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658677.7144431378, 6799320.273027931 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
