Api session event editor scenario
Api session event editor scenario Endpoints.
API endpoints for Scenario editing.
| Name | Description |
| add | Add new Scenario. |
| append_attribute | Appended to existing Scenario Attribute value |
| duplicate | Duplicate existing Scenario |
| remove | Remove existing Scenario |
| remove_attribute | Remove Attribute from Scenario |
| set_active | Activate Scenario, when testrun is active the Scenerio can restart it. |
| set_attribute | Set Scenario Attribute value |
| set_attributes | Set multiple Scenario Attribute values |
| set_name | Set new name of existing Scenario |
Additional API endpoints:
| add_event | Add empty dummy event that is Triggered on Scenario activation. |
| add_measure | Add a Measure that is Triggered on Scenario activation. |
| remove_cinematic | Remove Cinematic |
| remove_event | Remove Event |
| remove_measure | Remove Measure |
| set_cinematic | Set Cinematic |
| set_description | Set Description |
| set_event | Set Event |
| set_limit_neighborhoods | Set Limit Neighborhoods |
| set_limit_type | Set Limit Type |
| set_restart_testrun | When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps. |
