Api session event editor scenario remove event
API Endpoint: api/session/event/editorscenario/remove_event/
Description: Remove a Coded Event from a Scenario
0 REQUIRED (SCENARIO Integer ID) Scenario
1 REQUIRED (Integer number) Coded Event ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/remove_event/", options)
