Api session event editor scenario add event
API Endpoint: api/session/event/editorscenario/add_event/
Description: Add a new Coded Event that is Triggered on Scenario activation
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorscenario/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorscenario/add_event/", options)
