Api session event editor specialeffect duplicate pair
API Endpoint: api/session/event/editorspecialeffect/duplicate_pair/
Description: Duplicate Pair
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID) | Special Effect | |
| 1 | REQUIRED | (Integer number) | Integer |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate_pair/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/duplicate_pair/", options)
