Api session event editor netload generate paths
API Endpoint: api/session/event/editornetload/generate_paths/
Description: Generate Paths
| 0 | REQUIRED | (NET_FUNCTION Integer ID) | Net Function | |
| 1 | REQUIRED | (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) | Net Load | |
| 2 | REQUIRED | (Floating point number) | Double | |
| 3 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 14, 45 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], 10, 5 ]'JavaScript example POST:
body: '[ 1, 1, 14, 45 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_paths/", options)
