Api session event editor overlay set rasterization
API Endpoint: editoroverlay/set_rasterization.
Description: Set the type of rasterization a specified AVG or Distance Overlay should do.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an AVG or Distance Overlay)
1 REQUIRED (Enumeration) Rasterization type: FIRST, MIN, MAX, SINGLE_LAYER, GRID FIRST, MAX, MIN, SINGLE_LAYER or GRID
2 OPTIONAL (Enumeration) Maplink (will only affect the SINGLE_LAYER rasterization type): Building, Terrain, Area, Neighborhood
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "FIRST", "" ]'
JavaScript example POST:
 body: '[ 1, "FIRST", "" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/", options)
