How to add an Attribute
Revision as of 09:06, 24 April 2026 by Frank@tygron.nl (talk | contribs)
The right panel allows you to add new attributes. The top half displays existing Attributes, the bottom half allows you to add new Attributes.
Many Items in a Project, ranging from Stakeholders to Overlays to Buildings, have Attributes, representing properties that can be added, changed and removed.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an attribute:
  1. Select the type of data to add an Attribute to.
  2. Switch to the "Attributes" tab.
  3. Scroll to the bottom of the right panel, if necessary.
  4. For "Add new Attribute with name", enter the desired TQL name name.
  5. For "Add new Attribute with value", enter the desired value.
  6. Click on "Save new Attribute".
  7. The Attribute has now been added.
  • Adding an Attribute which already exists will change the existing Attribute value to the new value.
