Api session event editor specialeffect set particle pair location
Revision as of 13:41, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorspecialeffect/set_particle_pair_location.
Description: Set Particle Pair Location
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Integer number) Integer
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST:
 body: '[ 1, 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/", options)
