Api session event editor scenario
Revision as of 13:40, 14 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor scenario Endpoints.
API Endpoints for Scenario editing.
Name Description
add Add new Scenario.
append_attribute Appended to existing Scenario attribute value
duplicate Duplicate existing Scenario
remove Remove existing Scenario
remove_attribute Remove attribute from Scenario
set_active Activate Scenario, when testrun is active the Scenerio can restart it.
set_attribute Set Scenario attribute value
set_attributes Set multiple Scenario attribute values
set_name Set new name of existing Scenario
Additional API Endpoints:
Name Description
add_event Add empty dummy event that is Triggered on Scenario activation.
add_measure Add a Measure that is Triggered on Scenario activation.
remove_cinematic Remove Cinematic
remove_event Remove Event
remove_measure Remove Measure
set_cinematic Set Cinematic
set_description Set Description
set_event Set Event
set_limit_neighborhoods Set Limit Neighborhood
set_limit_type Set Limit Type
set_restart_testrun When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps.
