Api session event editor indicator excel min log time
Revision as of 13:34, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorindicator/excel_min_log_time.
Description: Excel Sheet Min Log Time
0 REQUIRED (Integer number) Long
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '94'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '3'
JavaScript example POST:
 body: '94'
fetch("https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/", options)
