Api session event editor geoplugin add
Revision as of 13:33, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeoplugin/add.
Description: Add new Geo Plugin
0 REQUIRED (Enumeration) Geo LinkType AREA, BUILDING, ROAD, STREET_OBJECT, TERRAIN_HEIGHT or WATER_BOTTOM
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"AREA"'
JavaScript example POST:
 body: '"AREA"'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/add/", options)
