Api session event editor indicator excel min log time
API Endpoint to Excel Sheet Min Log Time.
API Endpoint name is Api session event editor indicator excel min log time
| 0 | REQUIRED | (Integer number) | Long |
| 200 | Boolean (Content was updated) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '17'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '91'JavaScript Example POST:
body: '17'
fetch("https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/", options)
