Api session event editor specialeffect set particle pair location
API Endpoint to Set Particle Pair Location
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID) | Special Effect | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | double[] |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ] ]'JavaScript Example POST:
body: '[ 1, 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_particle_pair_location/", options)
