Api session event editor netload generate paths
Revision as of 09:08, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Generate Paths
0 REQUIRED (NET_FUNCTION Integer ID) Net Function
1 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Load
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 35, 6 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], 61, 13 ]'
JavaScript Example POST:
 body: '[ 1, 1, 35, 6 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_paths/", options)
