Api session event editor indicator excel min log time
Revision as of 09:05, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Excel Sheet Min Log Time
0 REQUIRED (Integer number) Long
200 Boolean (Content was updated)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '40'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '35'
JavaScript Example POST:
 body: '40'
fetch("https://engine.tygron.com/api/session/event/editorindicator/excel_min_log_time/", options)
