Api session event editor geoplugin add
API Event to Add new Geo Plugin
| 0 | REQUIRED | (Enumeration) | Geo LinkType | AREA, BUILDING, ROAD, STREET_OBJECT, TERRAIN_HEIGHT or WATER_BOTTOM |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeoplugin/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"AREA"'JavaScript Example POST:
body: '"AREA"'
fetch("https://development.tygron.com/api/session/event/editorgeoplugin/add/", options)
