Api session event editor indicator excel min log time
API Event to Excel Sheet Min Log Time
0 REQUIRED (Integer number) Long
200 Boolean (Content was updated)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '39'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/excel_min_log_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '23'
JavaScript Example POST:
 body: '39'
fetch("https://development.tygron.com/api/session/event/editorindicator/excel_min_log_time/", options)
