Api session event editor geoplugin remove link
API Event to Remove Link
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugin
1 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) Geo Link
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeoplugin/remove_link/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeoplugin/remove_link/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editorgeoplugin/remove_link/", options)
