Api session event editor specialeffect add particle pair
Revision as of 12:14, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Particle Pair
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorspecialeffect/add_particle_pair/?f=JSON&token=API_TOKEN
with content:
[ 10 ]
